Old 05-15-2011, 03:01 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by mentallydead21 View Post
vdOk so, I am looking into buying a 2JZ-GTE for a MKIV supra and was wondering what the major difference would be if I used a 5speed versus 6speed tranny. Such as cost, difficulty etc. Also, is it possible to take the 5speed manual from a 1jz and use it on a 2jz? The supra is automatic right now and I have looked into swapping, but most of the stuff I find is for 6speeds.
Also, what if I went with a 1JZ-GTE with the 5speed instead of the 2JZ for now. How hard would it be to put that into a MKIV?
Yes, it'll be a major difference...especially if you're planning to upgrade the 2jz-gte. The 5speed manual transmission can only take about half the max power/torque that the v160 can.
Please don't put a 1jz into an Mkiv. You might as well buy an n/a and stick with a 2jz-ge.
Life begins at 30psi.
