Yes, the cps works exactly like a distributor, get your number 1 cylinder at tdc on a compression stroke. move your ps reservoir out of the way and remove the cps all the way, align marks on gear and shaft. reinstall cps so the adjuster is centered on bolt hole(can be a pain cuz of the gears turning to mesh). lightly tighten it so its still moveable, start engine and use a timing gun to put it at approximately 10 degrees BTDC. put ps reservoir back on and your good to go.
