the vacuum line is connected to the actuator and there is no tear or leaks. As for the down pipe interfering with the waste gate I can not tell I think I'm going to put my old actuator on from my old turbo and see how that goes if it continues to do it then its my down pipe messing with my waste gate thanks for the heads up I did not even consider that to be an issue
I thought a boost controller could help my friend installed a turbo on a 87 325 bmw and was over boosting even with a build in waste gate set at 8 psi similar to mine. We installed a boost controller and it helped that's why I thought this is the same issue with my supra
