basically a high performance daily driver. so yea, if you want to drop the dough on them, the cp pistons and eagle rods would be a good investment.
lighten up the rotating assembly and be a lil stronger. not alot of ppl like the eagle rods, idk why, but they are good for the value as far as im concerned.
the turbo is a good start, and def the stopper gasket, combined with a set of ARP head studs would ensure plenty of clamping force for leak free operation.
after all that, a good down pipe and exhaust system would be worth a few hp.
if you really wanna drop some dough, some cams would pick up a lil bit too, but maybe too little for the cost.
a solid balanced bottom end build with a thoroughly machined and checked out head (maybe a small PnP?) with the aforementioned components would be an easy and streetable 400 hp i think.
if you wanna go all out, go stand alone so you can fully tune it and work out all the small kinks and tune it for exactly what you want.
