your going to need a full gasket kit, in addition to the metal hg.
you will also need to check if the crank needs turned, bore/hone etc.
bearings, rings, freeze plugs, timing belt, possibly cam gears, but some ppl have had luck without needing gears after milling the head/ block.
so basically:
pistons, rings, bearings, timing belt, gasket kit. then any new valves and shims.
