mm...cylinder 6 is a little crazy, might wanna try a comp test after you run it..but make sure the engine cools down...you dont wanna burn yourself, if its a high mileage motor you should expect at least one of the cylinders to be a little high, but if its that high...then u might have a problem
Now: Saving for an MKIV
Broken Rides:
