I suggest you buy a new OEM thermostat and housung seal. Install them.
Put in a new 50/50 mix of Toyota red antifreeze. Park you car nose high and "burp" the cooling system of air. Top off the coolant after voiding the system of air. Make sure your coolant expansion is filled to the correct level. Drive the car and bring it to operating temp. Monitor the coolant temp guage and stay close to home in case of issues.
You may find this will resolve your issue.
