El Supracabas- i marked everything and put the crank at TDC and marked the CPS and then put everything back together the same way.
And yes its getting to be frustrating....it needs to be on the road so i can cruise around with the targa off on these nice sunny days!!
I finally got to the open circuit relay...but how do i test it to see if it is good?? because my fuel pump still doesnt prime the fuel rail before i attempt cranking the motor.
