Old 06-11-2011, 12:46 AM   #2
El Supracabras
El Supracabras's Avatar
Post up the actual test numbers for each cylinder. No way they all have no compression. Otherwise a shot in the dark guess would be you somehow installed the cams with a valve open on every compression stroke. Not sure if it's even possible.
