Old 06-13-2011, 06:41 AM   #15
87hilux7mge
87hilux7mge's Avatar
Originally Posted by supraheelfan View Post
The oil pan from driftmotion is cheaper if you send them your own oil pan, so they can modify it. So with the new oil pan from driftmotion having 8 qts. should there be any reason to upgrade the oil pump as well??
true, but not by much in my opinion. and no, you shouldnt need a heavier duty oil pump with more capacity. although it wouldnt be a bad idea to shim the relief valve on the oil pump a few MM to bump the pressure at idle up a few psi.
and thanks cre, sorry if i was seeming, snoody lol...i was high spirited when i wrote that lol.
