Old 06-13-2011, 10:16 AM   #2
interested!
Question noisy cam?
Originally Posted by night-rider View Post
so i just rebuilt my engine and used a remanufactured cylinder head, it came complete and i never tore it down to chekc clearances or anything. there is a semi loud ticking noise from number one on the exhaust side, most noticible at idle noise goes away when rpm is increased to over 1000, seems a little worse when hot also, i removed the valve cover and checked all the valve lash within spec, seems highly unlikely to have a weak spring on a reman head? i will pull the cams and inspect the springs ect but i dont think im going to find anything obvious, has anyone ran into something like this before?
Hi!
I had the same type of noise on my brand new car -the garage found it ( I complained every time it went for a service ) after 12000 miles of gently running in --PISTON SLAP!!!!!!!! this was due to a slightly undersized piston fitted at first build that would rock at each stroke ( figure of eight ) giving the impression that I had a noisy cam / rocker ( the engine was a 4 cylinder - centre cam -V - mounted valves operated by rockers ) The garage rebored it and ground the crank under warranty for me and cured the problem.
