the stroked 7m is a nightmare as far as ive read and seen. only a couple have ran, and the results were less than adequate. you have to do alot of machine work to the block and either use shorter rods or custom pistons. if you buy the kit its easier, but its also 3k.
a 2jz is a much more reliable and easy to work with platform. making power with it will be easy.
not to say a 7m is a bad motor at all, but the 2jz is a newer and more refined platform.
if i ever get the money, id put one in my truck over the 7m.
