Your dad has it backwards...
BHG causes the coolant to dump into the catalytic converter that causes it to fail, get clogged up etc.
Tighten the head to 80 ft lbs. If you are palanning to run the engine for a relatively short time, dont waste you cash on expensive studs/MHG etc.
