Old 06-19-2011, 10:15 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by tayman1975 View Post
What is the compression rating my 1994 single turbo t78 with .20 cp pistons be for compression rating.
It depends on what compression ratio of cp pistons that were purchased. You can order pistons in many different compression ratios.
If your pistons were stock, or they were cp pistons at the stock compression ratio, I could tell you.
Life begins at 30psi.
