i assume you are getting a "click click click" when trying to start the car?
if so... i had the same thing.. couldn't be bothered fixing it so i found another remedy hehe
connect a wire to the terminal going to the starter motor... when click click click happens... make sure in neutral, turn key to ign... touch wire to pos terminal of battery... and car starts
if you are auto.. the neutral start switch is on it's way out
