The signal pressure required for the stock actuator to open partially or fully varies. As it ages it'll open at lower pressures and it'll start opening earlier. It's one of the more common reasons a person will assume a perfectly good turbo is shot. Yes, the actuator should move its full range (approx 1/2") with 7.4psi supplied... BUT it starts moving before that; how much before affects how quickly you'll come to full boost at WOT and there's still the possibility that the spring is weak and the gate is now fuly opening at just 5psi. Naturally, if the diaphragm is leaking it won't open until the boost is higher than expected. So, to simplify: A weak waste gate actuator spring means it may take a long time to reach full boost or may result in a drastic reduction of boost altogether. A leaking WGA diaphragm may result in excessive boost levels.
At any rate... I'm not sure this is what Austin is asking... The stock waste gate actuator won't let you go any further than the amount of pressure required to compress the internal spring (typically in the 6ish psi range on old, stock units).
There are two other questions which both seem more relevant:
1) What is the maximum pressure that the stock waste gate actuator can take before it gets damaged?
2) What is the maximum boost you can push before you outflow the built in waste gate and start having issues with over-boost/boost-creeping.
As you're not going to efficiently flow enough from a stock CT-26 for #2 to even be a concern I'll assume you're actually asking #1... The answer: Toyota specifies that the waste gate actuator diagram should never receive more than ~11psi. With an old unit you can take a couple more psi off that limit for safe continuous operation (say, 9 psi). If you're running on an old waste gate and want to increase your boost pressure it would be wise to run a bleed type type control valve versus a ball type. These bleed pressure before it ever sees the WGA. So (for example... and overly simplified) with 14psi in the manifold, a bleed of 8psi between the turbo and WGA the WGA still only sees 6psi.; Almost all electronic boost controllers operate as an electronically modulated bleed valve. With manual boost controllers the more sophisticated ones often include both a ball valve (preset for between 8 and 10psi) and a bleed valve (which you adjust to reach your target pressure).
