Check fuel pump flow rate
Had the same problem. Got the fuel filter off and decided to test flow BEFORE the filter. With the fuel test lead jumped and the key on the pump should be able to produce just under a gallon of fuel in one minute. Mine was doing less than a half gallon. Found my pump screen in the tank to be clogged. Cleaned scale from tank and replaced screen and happy days are back!
