Old 06-23-2011, 09:43 PM   #1
tayman1975
tayman1975 is on a distinguished road
Default Need advise what this might be for engine
Ok i got the compression readings off my 2jz GTE motor. Cylinder 5 is at 125lbs and cylinder 6 is at 150. The rest are at 160lbs. The shop noticed brassy color fittings in cylinder 5. What do you think this is. Doesn't sound like a broken piston ring. what do think it may be. Is it possible it may just have a bad head gasket you think.
tayman1975 is offline   Reply With Quote
