Welcome to the supra world. I assume you meant 86.5 not 96.5. All of the problems you are experiencing with yours are pretty much standard when you first get one. Its part of the ownership experience to slowly put the whooped, ill maintained car back together. 7M is a great engine but if your going to swap it just go straight to the 2jz, you will likely be happier in the end and it may increase the value of your car (which is hard!).
FYI, the headlamps must be on for the fogs to work. Not sure if you knew that. Otherwise search this forum as well as the internet, there are numerous write ups regarding diagnosing, repairing and modifying the fog lamp system. Good luck.
