Originally Posted by 87supra7mgte
is the wire that goes from the harness between the head/intake hooked up? should be a black wire with a blue stripe, plugs into a hard to see spot on the starter, its the switch wire for the starter to engage, if it is just start working your way back, relay, clutch depression switch, ignition switch, checking all grounds along the way, had this same problem after i replaced a BHG and it was simply the wire
I will check in the morning. Thanks. I have been going through my tech manual to see if there is anything else. Been staring at all of the diagrams. Seeing that the fusible link is a cause of alot of the issues that are going on so will check all that in the morning too. Will let you know what I found in the morning.
