Old 10-04-2005, 08:16 PM   #2
SupraMan1784
SP58GT
put more fuzzy dice on the car....ull probably be able to run 6's after that upgrade.....well if u wanna stay away from a turbo..try basic bolt ons... intake, header, exhaust...lets the motor breathe a little easier...then try upgrading the fuel system...pump, injectors...since ur getting more air in there this will add teh fuel you will need for a good stochiometric ratio, upgrading a throttle body always helps, and maybe getting the head done as well as teh valvetrain...upgrading the intake manifold to make it flow better and increase the volume will make more power, also trying porting and polishing the block and the head this will increase flow...you could also upgrade suspension, and the clutch...not increase in power but increase in response and acceleration, let us know how u want the car to be setup... we'll try and help you
Now: Saving for an MKIV
Broken Rides:
