Originally Posted by 87supra7mgte
total so far-16439.58
weak points considered-rear end and half shafts
500+ to the ground, will block handle this?
12-13 daily and around 20 at the track
would like to not stroke it
Dude, just buy a mk4. JK that is gonna be one expensive beast.
As long as the diff and shafts are in good condition and up to par on maintenance, i don't think they'll be the weak points. I'd put money on the rear suspension failing first.
Many 7M's are putting more than that down without the block causing problems. Search for their build threads to see, through their experience, the weakest parts of the engine and what to reinforce.
Make sure the head gasket and tuning is done by a rocket surgeon. That's a good amount of boost, you don't want all that money blowin up.
lol ... stroke it.
Good luck with the build, and most important, post progress pics.
