Originally Posted by Green7mgte
your gonna spend 250 on a lex afm? dude check your junk yards.
also if your going to be upgrading that much stuff grab a wideband and a safc neo.
"lol ... stroke it."
it would be nice, but the only kit ive found so far was like 2500, then would have to get the machine work done or whatever for the oil squirters, the block is gonna atleast get rehoned and the deck machined, but im trying to keep costs down as much as possible on machine work, have to start looking around for machine shops that can do that kind of stuff around here, 87hilux, is there any around you? my friend looked all around when he rebuilt the motor in his gsx and couldn't find any, ended up just gasket matching his ports, need to get more than that done with the oversized valves.
edit:just looked at stroker kit from import performance parts and there kit alone increased the 7MGTE to 320 HP and 315 TQ with the kit alone, and comes with H beam rods, pistons, rod and main bearings, pins and rings....this would eliminate the rods i was gonna get, making the price increase around 1500 or so, that might possibly happen come to think of it, and yes its gonna be tuned on a dyno, just have to figure out what standalone system to use, will look at the one recomended
