Originally Posted by sturner
Can anyone tell me where the two red arrows go to. I dont have a vacuum fitting on the passenger side of my motor and I dont see a vacuum fitting on the power steering reservoir. Oh and where does the purge line from the charcoal canister go to? After these questions have been answered I'll be done. Thanks in advance.
That vacuum valve is on the power steering pump, not the reservoir.
The other is a metal bracket with the vacuum tube on it mounted near the front driver side of the engine. There's actually a lot of vacuum lines running around over there, so it can be missed if you aren't looking in exactly the right area.
I'll have to take a look at my bay to see where the charcoal lines run.
