Old 07-24-2011, 06:48 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by tayman1975 View Post
My high beams work and the low beam light beside the high beams. The outside low beams and smaller skinny lights on both sides stopped working alltogether. I noticed a clicking noise under the hood and it was the headlight relay. I replaced it and it still doesn't work. I checked all the fuses and there all good. I put a test light to the connectors where the light plugs in. There is no power there anymore. I can't figure it out. Any suggestions to check what it might be.
Follow the troubleshooting steps in the TSRM (Toyota Supra Repair Manual). It has to be one of harness, fuses, relays, etc. You'll probably need a multimeter to check continutity in the harness.
Life begins at 30psi.
