Old 07-29-2011, 08:35 PM   #2
El Supracabras
El Supracabras's Avatar
The knock sensor is a one wire sensor. It has no ground wire. It creates its own voltage only when knock is present and is grounded via the block. If you are getting a knock sensor code, re check the wiring and connector or the sensor itself could be bad.
