That's no ct26.
Checking codes is in the faq section.
Breathers would be better than nothing but a nice functional catch can setup would be ideal.
Oil leaking from that line on top of your turbo will burn off quickly so it may not look like it's leaking. Make sure that fitting is tight. While you're at it make sure ALL the fittings and hoses are tight.
A leaking intercoler pipe will cause the car to run like crap, fix it.
Oil in the intercooler is not uncommon but excessive oil in the intercooler might mean the turbo is about to check out.
Keep at it, it gets worse before it gets better but after some time, research and money it will get better.
