Originally Posted by 97SupraTT
You have probably already considered it but there may be a clog in the system. Im sure you have already checked to see if your coolant is moving through the system but you could try and run some radiator flush through just in case there is a minor clog that still allows some coolant to pass through.
Done all of that. The heater hoses have not been changed. I will take a llok there.
System seems somewhat hard to purge of all the air. Would be easier if there was a purge valve at the top of the radiator.
Thanks.
