ign timing?
alright let me start out with this. yes I used the search button and looked through the FAQs I even googled it.
now that thats out of the way heres the question
I know that when you jump the box the timing is 10btdc on the 7mgte, But the engine is not in a supra and has a full wire tuck (which means no diag box) so what am I supposed to set the timing at without the jumper anyone know?
92 miata 7mgte swap ![Smile](images/smilies/smile.gif) forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
