Old 08-05-2011, 04:11 PM   #31
El Supracabras
El Supracabras's Avatar
Depends on what's leaking on the turbo. If it's coming from one of the fittings or flanges, you can fix it. If its coming from between the bearing housing and the compressor housing then it's time for a rebuild.
The computer will have identification labels if it is a toyota one. Is it idling with the O2 sensor hooked up now? Check codes again, it may have a different code now.
