Don't try to rebuild it yourself... I'm sure you haven't the tools to properly balance everything and at 10K+ RP you better believe that's a crucial step... You're liable to end up in the same position.
Get your IC professionally cleaned and THOROUGHLY clean out all of your intake piping with a solvent... All it takes is one chip from that impeller to destroy the engine.
Tip Jar ---> ![](https://www.paypalobjects.com/en_US/i/btn/btn_donateCC_LG.gif)
