ECU won't cut power to the dash or anything for that matter when the key is on. Sounds to me like part of the problem could be a bad battery connection. Check to make sure the terminals are tight/clean, and that the battery has a good charge (note: having SOME power does not mean it has a good charge, take it out and get it load tested)
