Oh good hell.... I just learned that i potentially blew a CT26 A then...
Rest is standard GTE fare tho afaik, has afm based system so guess someone just got hold of an A spec turbo... good job I didn't try a rebuild kit then
Anyone got impeller/turbine dimensions to hand?
EDIT-: further to this, having done some trawling the stock CT26 (which does have an A on the comp housing anyway) appears to have fairly even sized turbine/compressor housings externally, anyone confirm? Mine appears to be rather bigger on the compressor side...
