Old 08-09-2011, 04:46 AM   #1
dylansword
dylansword is on a distinguished road
Default Help me fix my hesitation and cut out!
I've got an 87 turbo. At about 3-5k rpms, it either hessitates ot completely cuts out.
It has the translator pro, aftermarket IC and piping, and full 3in exhaust.
It has new water pump, tps sensor, o2 sensor, spark plugs and wires.
The car came with the translator, because the pervious owner suspected the maf was going out. So I installed it and the car still has hessitating and cutting out problems.
Also, it idels high (the adjuster screw is all the way out), misses a little, and runs rich.
Any suggestion, or things to check will be greatly appreciated!
dylansword is offline   Reply With Quote
