I have had my supra in traffic on hot days with the ac on and have not had any overheating problems. If you are having a problem with overheating you most likely have a problem causing it. The supra is a modern car and was deigned from factory to be a daily driver. Also electric fans are a power gain only when the electric fan is not running since it will just transfer the load to the alternator.
