The stock fan is sufficient on the GTE if the clutch is good and you at least use the shroud. There are all types of electric fan options if that's the route you want to go. There are ready to bolt in kits that cost some coin, some universal kits that cost less but require some driveway engineering to fit and there is the junk yard route. Measure your radiator and its clearances then go to the junk yard and find one that fits.
As mentioned before, if you are overheating in traffic there is likely something wrong with the cooling system. The time and money would be better spent checking the condition of the cooling system components before replacing the fan set up.
