Big Turbo and nitrous is about the only way to get the numbers you are looking for. The car is heavy and the engine doesn't have a lot of cubic inches. But if you do upgrade the compression and go with some nice cams and headers and a set of side draft carbs, you will have a very fast car and nothing sounds as good as a straight 6 turning lots of rpms, sucking in a lot of air!
Russ
