You should see if there is a pick n pull near you, that'll be your best bet. Also I will look for it in my pal of extra parts, but no promises. You should also see if its a compatible part with other toyoda's. You might be able to get the part you need off another toyoda. But if I find it i'll send it to you no prob!!
I seen what you might need at
http://www.partstrain.com/store/
