Checking the base timing would be a good idea, especially since you removed the cps. Be sure to carefully check the wiring at the cps and it's connector, they tend to get roasted and frail because of age and heat.
Check codes again for a knock sensor code. The computer will pull timing if the sensor detects knock or has damaged wiring.
