Old 08-14-2011, 04:45 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by winnas13 View Post
Thanks for all that mate! good reading. The 'grinding' noise is more of a louder rattle from the gearbox, same kind of noise just louder. Yeah my mechanic said he will try some of that fluid and see how it goes.
Other than those issues, she runs great and pulls hard.
There are a few other noises that the car makes, i am thinking they are normal and i'm just not used to a performance car. Such as sometimes when i put it into 1st gear and start to take off, there is a bump or clunk from the rear...
It's pretty simple to change tyranny fluid; imho you should be doing that yourself. Either way, don't let your "mechanic" put some random fluid in there. It's a $5,500 transmission and the wrong fluid will ruin it!
The clunk is probably improperly torqued control arm cam bolts (from the last badly-done alignment by another "mechanic" who doesn't follow oem specifications).
Life begins at 30psi.
