Old 08-15-2011, 01:46 AM   #2
As far as I know there's not a bell housing which would let you use the W58 (You wouldn't want to use the W58 on a 2JZ anyway... too weak). You may use a R154 with a R154 bell housing from a 1JZ MKIII. You're going to need a different drive shaft anyway about it.... the MKIII Turbo drive shaft *might* fit, I can't recall.
