Nice car, don't krash it. I keed. Those are all common things for any old car, even more common on old supras.
If the a/c compressor doesn't engage check the fuse for the a/c first, then the refrigerant level.
Get a new stereo, stock leaves a bit to be desired even when it works.
Check the vacuum lines and wires to the cruise control servo by the brake master cylinder. Then make sure it is connected to the throttle.
If you hear a clicking under the dash when you hit the horn, it is either bad wiring to the horns or bad horns. If you hear no clicking, check the fuse.
Good luck and take your time with the car.
