Originally Posted by BradMD
hey just read the thread, im new here and don't know if its too late but is it possible to put the two stock turbos from a 2jz-gte onto a n/a engine, as i have just bought a 94 supra and it would be good if i could do that. So is it possible and what kind of work would need to be done?
Nope, the manifold the oem twins mount on doesn't fit the 2jz-ge head. In theory I guess it's possible with a ton of custom fab work (weeks and weeks, and thousands of dollars - really!), but it definitely isn't practical.
Your only practical options are:
1) Sell your n/a and get a true Mkiv TT (
this is by far your best option, since you get all the braking power, suspension, and bulletproof drivetrain of the TT - not just the turbos).
2) Put a
complete n/a-T kit on your n/a (which upgrades your turbos, your fuel system, head gasket, head studs, and your ignition). After that, you'll have to figure out how to upgrade your braking system (calipers&rotors, bmc, abs system, etc), suspension, transmission and and differential...when all priced out with labor will cost you more than the difference between a used TT and a used n/a.
