Old 08-16-2011, 01:44 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by BradMD View Post
Hi guys, i just bought myself a 1994 n/a auto Supra and at first glance it seems great, only problem is the heads blown and i know i'll be needing a new gasket, so my main question is will the Head Gasket for the Turbo engine work on a N/A engine, i'm only asking because the turbo head gasket seem to be cheaper. Also if anyone knows anything or has changed the head gasket before is there anything i should know or watch out for when changing it?
Thanks Brad
Why do you think the "head is blown"? The Mkiv never had the head gasket problems that the MKIII did, so I have to call into question your diagnosis of the issue, unless (for example) a large shot of nitrous was installed in this car?
Yes, the head gasket for the 2jz-gte will work on an n/a engine.
Get the TSRM for doing any work like this on an Mkiv engine...
Life begins at 30psi.
