If the fittings are not damaged you could try your local hydraulics specialist first they may well be able to remake the hose with new hose and crimps on the original fittings. That's what I'm doing with mine since they can use a superior grade hose rated for higher pressure, temp & abrasion resistance same as used for the lifting gear on my mates skip wagons etc
