The only fuse which will kill MOST of the cluster is the 7.5A Dash fuse. The cluster and the blinkers share NO wiring except for one minor thing; The interior signal indicators (the arrow lights) share a ground with the cluster (On the steering column or the floorboard, can't recall which). Do note that the signals will not work if the hazard switch is disconnected or defective or if the flasher relay is bad.
Tip Jar ---> ![](https://www.paypalobjects.com/en_US/i/btn/btn_donateCC_LG.gif)
