Won't crank, engine spins?
Fuel rail pressure, 38psi in the fuel rail.
It will try to start... with a shot of starter fluid... so that means the plugs are getting fire.
Meter tested the wires back of plugs of ecu... getting 10 volts at all three injector wires when tested with E1 or E2. Was expecting to get nothing, buddy says I need to replace the ECU, thought that test would confirm... Supposed to hand me a ECU tomorrow, if it solves... I'm good, but I don't see why an ecu would just up and quit.
