If I remember right, the o-ring goes between the lower tube and the block, the upper tube slides into the lower tube and is then held in place by bolting the tab on it to the turbo.
The sender and wire for the oil press gauge are on the hot side of the engine so look for damaged wiring and possibly a cooked sender.
