Old 08-19-2011, 02:58 AM   #1
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
Default Exhaust gasket's
Okay, I have a 3inch down pipe and 2.5inch exhaust. I went up to summit racing to buy gaskets for my exhaust but they had none that would fit my car......I don't know how many other people have this problem but this is how I went about it and maybe it might help someone
I purchased a sheet of Mr Gasket 24inches long and 8inches wide
I then traced every line, when doing this pay extra attention to the bolt locations and holes.....They have to be perfect! I used industrial wire snips
and it leaves kind of a jagged edge. I will show you what I did to take care of that.
So then I placed the gasket in a clamp and used a drill to poke holes where the bolts will go through and where I will snip a hole out of the middle for the exhaust
To smooth out the edges I used a zip tool with sand paper round bits....It takes a while but I believe to have a good seal it had to be done
Here is what I ended up with...Not bad for my first time I think....Going from left to right you can see I did get better and better as I went on
I actually had fun doing this....Nothing like custom fabricating your own parts....Even if it is just some gaskets lol
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
supraturbo_mk3 is offline   Reply With Quote
