Old 08-30-2011, 01:50 PM   #4
Sonyps307
For code 42 does ur speedo work if not then the speedo cable coming form the transmission is broken. so the speedo sensor is not getting a signal. If it does work then the speed sensor is bad. I don't know if that is causing that problem or not. Now for the code 11 check the main grounds for the ecu. they r 2 brown and 2 white wires that r bolted to the intake right above the starter. Just try cleaning them first and erase the code to see if it comes back again later.
Check out this site
http://www.mkiiisupra.net/joomla/ind...d=24&Itemid=29
